What happens with a power outage?
spwath
MY parents want me to turn my computer off or get an UPS because our power goes out often. Why? What happens with a power outage to my pc?
well basically lots of outages will damage your stuff epecially if the power supply is inadquet, a ups ensures that there is always a constant supply of power so if there ever was an outage u can turn it off safely
now it my turn to ask a question, how often does power go out?
Nothing usually. Unless you are doing windows updates, then your computer might be displeased.
no need for a UPS unless you are doing critical work and don't save it often. A UPS is usually just a surge protector with a battery to keep the thing running for a couple of minutes (just enough time to save your work). A power outage will just turn off your computer the same way as if you were pressing the power button for several seconds to abruptly shut down your computer.
What is much more important however is just to get a cheap surge protector to protect from sudden variations in current that could destroy your pc's components outright. That costs a lot less than a UPS
Here's one example of a surge protetor
"Common sense is not so common." -Voltaire
Depends, really. Normally, it'll just shut off and you might get a message from your OS next time you boot saying that it didn't shut down properly.
However, if your computer is in the middle of saving a file, said file could get corrupted. Even worse is if your OS is updating at the time, which could lead to the OS getting corrupted, which may make it so you have to reinstall.
CPU: i7-3820 | Cooler: Be Quiet Dark Rock Pro 2 | Mobo: Asus Sabretooth X79Memory: 2x8GB Corsair Vengeance LP | Storage: Crucial M500 240GB & 480GB SSD + Western Digital BLACK SERIES 1 TB |
GPU: EVGA GeForce GTX 780ti Superclocked | PSU: 1000W Be Quiet Dark Power Pro 10 | Monitors: 3 x AOC i2367Fh 23.0"
All hail the mighty Flying Spaghetti Monster. May he touch you with his noodely appendages
That's not really a surge protector, but rather a power strip.
Here's a surge protector:
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
I have a surge protector. Our Tivo broke from a power outage, and it was plugged into a surge protector. So when im not using my computer (at night, when im at school) there is no need for me to make my computer sleep?
Not that much, seems to be less recently, but it goes off for like a second around 6-7 times a year with 1-2 additional extended times-
oh then no need for ups just get powersurge protector like the hawaii said lol u said it goes out often so i thought that was like couple times a month or sommin
its like turning off the plug to everything computer dont like it but 10 times a year wont to much just keep a backup incase it goes out during an update or something important
There might be a small surge that leaked from the surge protector and broke your tivo. If you are not using your computer, just turn it off unless you really want fast boot times when you turn it back on.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
I'm fairly sure I have a surge protected power strip on my computer but you also have to worry about your router if you have ethernet directly from your computer to router. I haven't had any problems with this sort of thing but I've heard stories of a surge getting sent from a router through the ethernet cable and frying motherboards and stuff.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
Hmm Ok. Ill see. seems kinda unlikly tho.
many surge protectors break after a while. Some of them have LEDs that will notify you if it still protects you against power surges. If the LED is still lit it means the surge protector still work.
Oh and here's a cheap surge protector I recommend ($8 on amazon). It has a LED to let you know if the surge protector still works.
http://www.amazon.com/Tripp-Lite-TLP606-Protector-Outlet/dp/B0000AI0N1
mine has an LED so im good. I stole it from our family computer cause it dont need a ups and a surge protector, ups has it built in. The one i have is nice with adjustable plugs. Now, it has 2 lights, one says "protected" other says "grounded" only protected is light up. back downstairs grounded was light up too. is this a problem?
doesn't need to be grounded it's alright. I even cut off the ground on many of my devices (the third circular power prong) in order to use my laptop power plug in other countries without an adapter and I've never ever had any problems haha (only time I ever got electrocuted was actually by a grounded power plug lol). The surge protector and ground have nothing to do with each other. The ground is to protect yourself mostly.
Power went out once at my dad's house and his PC was on... His motherboard is shot now. Has to buy brand new mobo and cpu and RAM (because it was an older mobo).
I would look at a line conditioner instead of a surge protector or UPS.  That's the real danger to components, dirty power.  And power is especially dirty during brownouts or when power goes out/comes on.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
ups would be a good idea in your situation. It will at least help make sure you don't lose any data or projects you might be working on at the time.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
Random Power Outages can be bad for your components, we had a SSD in out HTPC dies because my dad accidentally killed the power.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
does anything that looks like that is a surge protector generally?
CPU: Ryzen 2600 GPU: RX 6800 RAM: ddr4 3000Mhz 4x8GB  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
Dang, the OP owes the parents some internet cookies, prematurely protecting the kid from a fried computer, best news of the week. Get the freaking UPS, they already approved it.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
I have had the power go out many times when using my computer (very, very many) but the only time when it has actually damaged a component was when it was a air conditioner thing, the fuse didn't stay off and kept ticking on. Basically the power went off and on really rapidly for about 5 seconds
if it just goes out and stays out, there is not much of a risk there, but if it goes out and then comes back very rapidly in the span of a few seconds, there is a very good chance that you could damage your power supply, or an internal component, especially if you have your computer set to reboot after a power outage.
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
If you get thunderstorms in your area a lot a good surge protector is a good thing to have, I usually unplug my sensitive electrical equipment but around here in the summer storms can develop very quick. I had a storm blow out a bunch of fluorescent bulbs in my house one time. The surges from lightening is nothing to mess with. As far as power outages, going out and staying out will not miss up things usually, but the dimming of lights or just barely going out and right back on is much worse.
"Science and technology revolutionize our lives, but memory, tradition and myth frame our response."
Arthur M. Schlesinger
Agree'd. Especially if they're paying.
Just curious, are these outages random or predicted? Where I am there's a random outage once or twice every five years or so, and they're almost always at night. The only time other then that is if there's a nasty storm, and in that cause I turn my PC off anyway, and use my laptop of I really need the internet.
| CPU: AMD A8 | MOBO: MSI 7778 | GPU: Asus GTX 650Ti | Case: Corsair 200r |
| SSD: PNY 120gb | HHD: WD Blue 1tb | PSU: Cooler Master 750W |
| peripherals: Corsair Vengeance M65 & Razer Black Widow Ultimate |
yes generally. If you go to a hardware store or a tech store it should definitely say something like "storm protection" or "surge protector" somewhere.
