Need suggestions for my first DIY PC
8 minutes ago, beevk said:Just to be sure, when you say overclocking here, you mean overclocking CPU, right? Can you enable XMP without overclocking CPU? What does overclocking RAM means? Sorry, if I sound stupid. I just started researching about hardware from last week and am really curious to know now.
So, DDR4 ram has a base speed of 2133MHz. However, you can get it to run at up to 5000MHz by overclocking it. You can manually overclock it by changing frequencies, voltages and timings or you can have it done by enabling a setting called ‘XMP’. This is put onto the RAM by the manufacturer before being sold. In the motherboards bios, you can enable this and it will automatically set the frequency, timings and voltages for you.
No, I mean overlooking the RAM.
8 minutes ago, beevk said:Can you enable XMP without overclocking CPU?
Yes, you can enable it without overclocking the CPU.
8 minutes ago, beevk said:What does overclocking RAM means?
Overclocking RAM means changing the frequencies, timings and voltages in the motherboards bios.
