HELP
Go to solution Solved by SansVarnic,
-= Topic Merged =-
-= Topic Moved to Troubleshooting =-
One topic on the subject is enough.
hello guys,
i have a mobile which was brought in 2016 its model number is samsung a9 pro.please make sure to watch the video the problem is when i check the storage size it says it has consumed 16 gb but when i enter the folder and select the file indivisually it says it has consumed 2.6 gb what is going on. please help
https://linustechtips.com/topic/1205602-help/
hello guys,
https://linustechtips.com/topic/1205602-help/#findComment-13687143
13 minutes ago, nischayvm said:
do you think that android consumes 10gb of os
Depends on the version and storage size, but Android 10 takes up 16.7GB on my phone.
You'll get much more accurate readings of what's consuming storage in the phone's UI itself rather than in Windows.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1205602-help/#findComment-13687214
The UI matters
I have a stock android phone ( a pixel ) and android takes around 5-8 gigs but if you have a heavy skin it might take a whole lot and bloatware also matters
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1205602-help/#findComment-13687276
-= Topic Merged =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1205602-help/#findComment-13687829
@nischayvm Maybe the question of contact will help.
https://www.quora.com/What-is-the-size-of-Android-8-0#:~:text=Download size is just under,rom size to install Oreo.
I will quote
Download size is just under 3gb, and after installed on any device that is at least 3gb ram, then will be taking up to 7gb storage from internal. So as the other one said you need to have at least a 16gb rom size to install Oreo.
I see you are suffering to understand the eMMC type disk size. It's just SATA speed flash memory. Might also be used as the virtual ram space. Your Chromebook (if any) is just the same.
Textisaurus; shipping from life with love, stantsiya mir was a weird encounter, stantsiya novy afon...
https://linustechtips.com/topic/1205602-help/#findComment-13688125
