As I'm sure most of you know, getting power supplies right now is difficult to say the least. I just finished a build, and in the course of trying to source a PSU, I managed to actually get two. Now, I'm not sure which to actually use. Here's the basics:
My build:
ASUS TUF Gaming X570-Plus WiFi
AMD Ryzen 3700X
Sapphire PULSE Radeon RX 5600 XT
G.skill Ripjaws V 32GB (2x16GB) 3600MHz
WD Black 500GB NVMe m.2
The PSUs:
Silverstone Strider 700W 80+ Titanium (ST70F-TI)
EVGA SuperNOVA 650W G+ 80+ Gold (120-GP-0650-X1)
I don't care about efficiency here, really, just overall quality. The 50W difference doesn't matter much, as I'm only at 50-60% load as it is. Both units were roughly $150, which seems to be high for the EVGA and low for the Silverstone, but again, didn't much choice on this part of the build. Regardless, cost isn't a factor. The only thing I see as really differentiating is the warranties. With EVGA, I get 10 year, but the Silverstone only has 5. However, if it dies after 5 years, I'd probably go buy a new one anyways, rather than go through the hassle of an RMA.
Any thoughts?
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1204021-comparing-two-power-supplies/
Sadly I can't comment about this psu's quality
This one is really decent
And it should last you for a while
150 dollars for a titanium unit ??!!
That is not promising
Phone: Pixel 3a (Purple-ish).
Build Log:
If you are in the US, I'd go for the Corsair TXM Gold 650 W, if you don't care about modularity too much. It's only $115 (including shipping) on Newegg right now.
If you are in the US and want a fully modular PSU, the be quiet! Straight Power 11 650w Platinum and Straight Power 11 750w Gold are only $135 on B&H.
If you aren't in the US, please tell us what country you are shopping in so that we know where to look for PSUs for you.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
From what I can tell, the Silverstone retails for around $200, but I got it off Amazon for $150 by some fluke. From reviews I've read, it seems it's only *just* titanium rated. Apparently, they took some short cuts to get the rating, while keeping cost lower. The ripple is not great, for example, but I'm not planning on heavy overclocking, and it's not technically problematic until near 100% utilization anyways. Where I'm at, the ripple is higher than some units, but still within a perfectly acceptable range, even for overclocking.
If they had to cut some corners I would go for a perfectly good 80 plus gold rated PSU
I would take quality over efficiency 100% of the time
Build Log:
5 hours ago, spartaman64 said:
Thanks for those. I looked at reviews for each unit already, but couldn't find any from the same source. That's as close to a head to head as I'm likely to get.
That's pretty much my thinking as well. It's not like either is inefficient, and so what if it costs $1 or something more a month. No biggie. Between the longer warranty and the better overall scores, I think I'll be sticking with the EVGA.
