Budget:575 euro
Games, programs or workloads that it will be used for: Blender, krita video editing software, audio editing software and games
Parts:
Motherboard: MSI A320M-A PRO M2
CPU: Ryzen 3 3100
GPU: RX 570 Armor 8GB
RAM: GoodRam IRDM X DDR4 8GB *2
storage:Toshiba 1TB HDD, Kingston 120GB SSD
Power:  Modecom MC-S85 500W
Case:Deepcool Matrexx 30
Is there anything i can change?
https://linustechtips.com/topic/1200078-first-pc-build/
I'd probably try and find a better PSU, and try and save at least enough for a 3300x.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1200078-first-pc-build/#findComment-13644147
8 minutes ago, BwPEKKA said:
Budget:575 euro
Parts:
CPU: Ryzen 3 3100
I would not build a computer right now. Motherboards are too expensive due to the shortage.
If you are using a 3rd gen CPU, you really want to have at least a b450 motherboard. A320 is not good enough in my opinion for that CPU. It was made for budget first gen ryzen.
Also, change out your power supply. Get a cheap corsair / evga instead.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/1200078-first-pc-build/#findComment-13644153
Location and budget please.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1200078-first-pc-build/#findComment-13644158
A cheap Corsair/EVGA could be an old orange VS or an N1, which could be just as bad.
Get a half-decent B450 board, like a B450M-PRO VDH Max from MSI, ditch that PSU for a CX450, and I'd try and save up for the 3300X instead of the 3100.
Check the used market for RX 480s and 570s if it means the money saved there could go to one or more of the components I mentioned above.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1200078-first-pc-build/#findComment-13644173
