monitors don't shut down as required.. any help?
Lii
Hello
the thing is that I have more than one monitor
and I don't always use the other ones, so to me it seems a waste of resouse to mantain those one, so I usually manually shut off and wake up
but is there simple way to let know to the pc when shutting down those monitors and when its needed to wake up them?
( for example I put a window to the space where my other monitor is, by so it turns it on, and shut them off when there isn't an active window for some time in their area)
Hello Somebody can tell me why is doing this thing? https://mega.nz/file/3jBFjKIK#zSiM78yhWrGcoqrFDNE-dk_eSjkhSQ_ZlmK7gYxiRAQ Also when I do pc screen only, it shut off all monitor except the monitor that is numbered as 1, though is not setted as a main monitor, the main monitor is the number 2
On 5/25/2020 at 5:52 PM, merco said:
Yeah press Windows key + P and select your option.
Thanks
And up
