Budget (including currency): whatever
Country: US
Games, programs or workloads that it will be used for: Minimal logging, VPN support, split tunneling
Parts:
Intel E1G44ETBLK 82576GB Gigabit Quad Port PCI-E x4 Server Adapter - DELL HM9JY (already have)
i3-8100T
Noctua NH-L9i
Prime H310I-Plus
Crucial Ballistix 2x4GB
Team MP33 128GB M.2 NVME
SeaSonic 300W SFX
https://pcpartpicker.com/list/MwQT9G
I know it's pretty overkill for my needs. Most of the pfsense boxes you can buy use Atom processors, though I did see one that used a laptop or SOC i5. This i3 is a 35w part so I'm ok with that. What I like about this is that it uses normal memory instead of SODIMMs, and seems like the parts are readily available. I'd certainly be open to an AMD solution but I wasn't seeing parts in stock that were lower TDP, used AES-NI, or both.
There aren't a lot of current builds out there for this kind of thing. I'm seeing a lot that use obsolete server parts, but either those parts are no longer available, or they've gone up in price so much that it just doesn't make sense compared to current consumer stuff.
I'm going to throw this in the smallest Silverstone HTPC style case I can, because they're fairly cheap and will fit on a closet shelf. I have a 200mm fan exhausting from that closet into my master bedroom closet so it stays quite cool. Even with the fan running at roughly 25% speed. I'm pretty happy with that solution.
I also have a stack of 750GB laptop drives that I might make an unraid server with...but that's a separate build. Thanks for the feedback.
https://linustechtips.com/topic/1198914-pfsense-itx-build/
10 minutes ago, Z3R0 CHANC3 said:
Noctua NH-L9i
thats way overkill, stock cooler is more than enough
ignore tdp, it doesn't matter here. Idle power is what youcare about. And in that case, all modern cpus are pretty much the same. Just remove all the extra things you can to save power.
dell r210ii are pretty common picks, there about 100 bucks used, pretty quiet, and more than enough horse power.
what bandwidth are you working with? Id be tempeted to get a nuc or simmilar, even lower power.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13635491
Yeah but even that Noctua isn't very expensive...but I didn't think the 8100T came with a cooler.
I'm not using a 1U chassis just because of the depth. Some of those Silverstone cases are only 9" or so deep.
Right now I'm at 300/30 speeds but Gigabit is available here, though I'm still hoping that ATT gets fiber to my neighborhood.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13635519
Im pretty sure it has a stock cooler.
Also is the 8100t cheaper? Might as well get a 8100 or 9100 if there near the same price.
Id still look for a nuc or simmilar
yea that will easily route gig fibre. I got att gig fiber, its nice, but have fun with their router box.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13635675
4 hours ago, Electronics Wizardy said:
Id still look for a nuc or similar
That just isn't much of an option, to be honest. Yeah there are some out there, but trying to find a good one.... well that's tough.
1. CPU - many aren't great, and the biggest reason I want to do this is to NOT have VPN slowdowns. I could just flash my router but I know exactly what kind of speeds I'll end up with-less than half of my potential speed.
2. Network support: dual NIC (minimum), or a PCI-E slot for the NIC I already have, or an M.2 breakout to connect a nic, outside of the case, which looks jank AF.
3. Or getting everything I need and spending $600+ when I can do a better box for less with off the shelf stuff.
So I can sort through hundreds of NUC/SOC setups, potentially spend even more money, or spend $400ish now on a system that is definitely overkill...but who cares, if the price is right.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636492
4 minutes ago, Z3R0 CHANC3 said:
I'm assuming they convert from fiber before the router?
yup, you get a ont. But then thta connects to their router with 802.1x, so you can't just plug your router in. You need their router to do auth.
How about this guy? https://store.netgate.com/SG-3100.aspx
offical pfsense support, and ready to use.
Or go more diy with this guy
https://www.amazon.com/Pfsense-Q330G4-I3-4005U-4Gigabit-Firewall/dp/B074XNYHL4/ref=sr_1_7?dchild=1&keywords=mini+pc+router&qid=1590285032&s=electronics&sr=1-7
ALso, do you need pfsense, There are other options like untange and opnsense, that I like more.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636529
My Linksys router (WRT3200) has a an ARM processor, dual core at 1.8Ghz. And it falls on it's face with VPN enabled. I'm not married to pfsense but nobody online is talking about this stuff, it seems. Nothing current, anyway.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636564
wht vpn bandwidth do you need?
You can compare a cpu like there, there is much more than core cound and clock speed.
why not try the router oses on a vm?
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636568
1 minute ago, Z3R0 CHANC3 said:
I'm really not asking for alternatives to the build I want to do, but thank you. I do appreciate the feedback.
If you still wnt itx, Id probalby get a non t sku, use the stock cooler. Probalby get a 16gb optane m.2(faster + cheaper + probably more reliable).
Also just saying, if you already have a server, you can run the vpn on that for much more speed.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636588
Appreciated. Though I don't already HAVE a server, I do need one (ok I'll be honest, WANT one). It may make more sense to run a VM on a server and kill two birds with one stone. That may turn out to be the genius suggestion that I hadn't really even considered.
https://linustechtips.com/topic/1198914-pfsense-itx-build/#findComment-13636767
