Search In
  • More options...
Find results that contain...
Find results in...
Need help Deciding a keyboard from Corsair.
vbob100
 Share
Hey,
I've come across a fork in the road, I need help deciding on whether to get the Corsair K95 with speed switches or K70 MK.2 with blue switches. They are both available for the same price. I like the clickyness of blues but, how well does that work out for daily use, will it get annoying and such. I'd like a switch that is "comfortable" for typing and gaming. Should I go with the K95 for clout, RGB light bar, and dedicated programmable keys. This will be my first mechanical keyboard purchase. I don't know much about how mx speed switches feel since I never tested them. My current keyboard is a Dell Multimedia Pro, I use the home and calculator shortcut quite a bit, should I go with the K70 and remap pause/break and print screen keys or get the K95 and use the G keys, do such shortcuts exist in icue, if not I could probably learn to live without the shortcuts.
In summary, whats a good switch for typing and gaming, K95 or K70, and what are your opinions.
Links:
K90 Platinum
https://www.bestbuy.com/site/corsair-k95-rgb-platinum-mechanical-gaming-keyboard-cherry-mx-speed-rgb-led-backlit-black/5713210.p?skuId=5713210
K70 MK.2
https://www.amazon.com/gp/product/B07D5W7R2X/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
I'm also open to any corsair deals that y'all might find to be better.
If they're the same price, I feel like you're getting more for the same price out of the K95. I also have the K95, and I like the MX Speeds. I enjoy the tactile feel of blues, but I feel like they get inconvenient after a while, when your mic is picking up every key stroke, and people can hear you typing from different rooms.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Both are very mediocre keyboards, even among other modern "gaming" keyboards.
I'd build a custom but if these are your only two options, get whichever one that has switches you prefer (try both, maybe).
Quote me to see my reply!
SPECS:
CPU: Xeon X5650 OC'd to 4.2GHz @ 1.35V (courtesy of @XR6)Motherboard: Asus Sabertooth X58 RAM: 6x4GB G.Skill Ripjaws X GPU: Asus RX 570 Strix Storage: 512GB Samsung 850 Pro and 1TB WD Blue PSU: EVGA 600B Case: Fractal Design Define C Cooling: H100i V2, be quiet! Pure Wings 2 (two intake, two exhausting through radiator) Monitor: 3x Dell P2210 on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: It changes, but usually Focus FK-9000 Mousepad: Steelseries QcK XL Headphones:  Sennheiser HD598SE and MEE M6 Pro
"If you don't measure things, it's not engineering; it's art." - Jack Ganssle
If you want to play it safe, Brown (tactile) switches are used by the vast majority of people (result from 2017 r/mk poll).  If you haven't really tried many switches they are likely the right choice.
Since you can get both for the same price, I would pick the K95.  But why do you specifically want a Corsair board?  Their boards are pretty expensive for what you get and their only defining feature is the RGB.  In most other threads we usually recommend other brands such as Ducky who often have better build quality for less money.
1 hour ago, vbob100 said:
Hey,
Links:
K90 Platinum
K70 MK.2
Why you dont try this one https://www.newegg.com/steelseries-apex-3-rgb-gaming-keyboard-10-zone-rgb-illumination-ip32-water-resistant-premium-m/p/N82E16823239056
CPU Ryzen 5 3600X OC 4.6                  Mobo Asus Tuf Gaming Pro B450                 DDR4 16GB 3600Mhz Corsair Dominator
Gigabyte 1070 Ti              Arctic Liquid Freezer 2 240             Cooler MasterMB511 Case With 6 TT White Ring Fans
1 hour ago, Haas_ said:
Why would he chose a membrane board over a mechanical one?
Maybe just to try it, bcs mostly reason why people buy mechanical keyboards are only bcs everyone else is buying it curently :)
That's not true at all.  The vast majority of people buy mechanical keyboards because they offer a much nicer experience to type on.  Any recent surge in mech board sales are likely cause by people spending more time on their computers and now realising that they would prefer using a mech board
23 minutes ago, kelvinhall05 said:
I'd build a custom
doubt he'd do that, it is probably way more expensive than what he is prepared to spend. however, what about something like a ducky?
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
I could try that, but I'm trying to keep my desktop an Asus/Corsair build.
So you really want only to have PC in two build factory. Lol thats waste of money. Buy what is best for money to performance thats my moto.
Its so nice to here click clack sound while playing :) Lol pls its like fashion 1970Lewis is back in 2020 :)
what the hell are you talking about
CPU: AMD 3600X
PSU: EVGA B3 650@
Case: NZXT H510
I could describe it like the apple ecosystem, because of it popularity there's usually a lot of community mods. There's also simplicity, ique can control a lot. I don't want to have a seperate app to control motherboard rgb and a seperate app for keyboard and etc. I kind of think of it as the pc version of the "apple tax," I'll pay more now but in the long run it'll pay off on support, software, and warranty.
I gave that a look, I think I'll just stick with something that can easily sync up my rgb and doesn't require extra software. I'm also looking for a full keyboard layout with volume knob and preferably media keys, I think it would be cheaper to go with a corsair keyboard than to build a mechanical keyboard with similar functions.
 Share
