LAN Transfer Speed Is Too Slow
6 minutes ago, Eigenvektor said:Also keep in mind that e.g. 300 Mbps (Megabit per second) is about 37.5 KB/s (Kilobyte per second).
No.. you divide by 8 to get bytes per second. So 300 mbps (mega bits per second) = 37.5 mega bytes per second
For fastest speeds
You can buy two usb ethernet cards ... if they're both gigabit cards, you can use a regular ethernet cable to make the connection between them. If they're 100 mbps, you need a crossover cable (you can make one or buy one) ... then you give each laptop an IP (ex 192.168.0.1 and 192.168.0.2 and same subnet mask 255.255.255.0) and you're done.
There's some really cheap usb cards out there, as low as 1.7-2$, here's an example from a seller with loads of sells : https://www.ebay.com/itm/USB-2-0-Fast-Male-To-RJ45-Female-Ethernet-LAN-Card-Dongle-Adapter-10-100Mbps-IFA/351544236206?hash=item51d9ab58ae%3Ag%3AKC4AAOSwtlhWF3AY&LH_BIN=1
If you don't want to buy hardware, the best advice i can give you is to configure a ftp server on one of the laptops ... Filezilla ftp server is free and super easy to install and configure and you can stop or start it at any point, only when you need it.
On the other laptop, you can use filezilla ftp client or any other client to either get or send files to the other computer... the benefit is you can transfer multiple files in parallel , and you get resume support and overall ftp can reach higher speeds than regular windows shares.
yeah overall the bandwidth will be limited by the connection speed of the network cards .. for example you may have one laptop connect at 72 mbps up and 72 mbps down (up to around 8.5 MB/s ) but if the other laptop can only connect at 54 mbps or less, you'll get less than 54 mbps.
