Budget (including currency): $750ish us (lower if possible )
Country: US
Games, programs or workloads that it will be used for: racing games, JWLIBRARY and Zoom at the same time, multiple chrome tabs with combination of preceding uses at the same time
want to game at 1080p 60fps; building asap
What I have:
friend has a case for me (don't know if it has fans)
Just bought a AMD Ryzen 5 3600 from b&h for $175
What I don't have yet:
Don't know if I should go with a x570 or b450
Would like to have a 500gb m.2 ssd
16gb 3200mhz (2x8)
Gtx 1660 super- if you think I should go with a amd card please give reason why. Thanks
Psu: looking for recommendations
https://linustechtips.com/topic/1194686-first-pc-build-3600/
Country: US
What I have:
16gb 3200mhz (2x8)
I would return/cancel the order for the r5 3600 and wait for geforece 30xx, ryzen 4000, and b550/x670. Otherwise I can't recommend a b450 board because of future upgradebality and x570 is really expensive. The adata sx8200 pro are good and cheap m.2 nvme ssd's. Buildzoid has a ram buying guide so watch that. Nothing against the 1660 super. For psu's get at least b+ or b tier psu
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1194686-first-pc-build-3600/#findComment-13603399
If you're on a budget go with B450.
There's really no reason to get X570 TBH. Not unless you want PCIe 4.0, or a nicer looking board.
You're only really missing out on one generation, maybe two before they change sockets if you go with B450. It's not that bad.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1194686-first-pc-build-3600/#findComment-13603500
