Going to be up grading again..
Solved by Fasauceome,
4 minutes ago, BlueEyesWhiteDragon said:Newegg has the three combo for under $300
Ryzen 3 3100 launches in days, and the performance appears quite excellent. Use that with this parts list
Just now, BlueEyesWhiteDragon said:I guess my next move is upgrading to a ssd. as the harddrive rn is VERY slow. And loud! lol
But I want to avoid overclocking... does this very the results in the mobo and cpu selection.
In which case the PBO feature will do everything you need. You still want good power delivery. The Max series is also guaranteed compatible with third gen ryzen, but the strix B450F is not.
