I have a very nice looking water cooled build that is ruined by some pesky noctua fans. They're gross. I have enough SP120 fans around to replace them, but I'm worried about noise. I have some voltage enough voltage reducers so they will run at 7V (idk if they're pwm). The point of the build is to be very very quiet. How loud would they be? Is it worth it for the aesthetics?
Thanks!
I should add that they're quiet edition fans.
https://linustechtips.com/topic/119003-fan-aesthetics/
It might be worth it. Might run warmer. And I'll take all your Noctuas (if they're free). ;)
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586921
Barely Audible.
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586922
Why run warmer?
My noctuas would ruin your aesthetics :P
Oh, forgot as opposed to running at higher speeds. xD And what asthetics? I have a red case, with a blue fan, blue mobo, gold NB heatsink, yellow, white, and blue slots, and a HDD with a blue PCB. This computer is the definition of rainbow.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586936
SP120s are loud man. I have two Quiet Editions in my rig, I turn every fan off except those two (because I can't) while idle. Quite audible, though I usually have my ceiling fan on with or without headphones on.
NB Eloop Master Race
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586944
not nearly, I bought some and they are insanely loud
I think I have made my decision!
Not even close to worth it. I'll sell and replace my noctuas with gentle typhoons or eloops. Thanks.
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586957
is that a joke? LOL
So true, When I read that comment I laughed.
SP120's have to be one of the loudest fans in existence.
35 dBA at 12V. So loud!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586986
I have gt's and can't hear them with my ad900x's on, but if I plug 2 nf-f12's in as front intakes, I can hear them instantly through my headphones.
I hear good things about e loops, although haven't tried them.
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1586995
I don't get why Noctua is so in love with those colors! Arggghh
It's like a way of knowing you have some of the best fans on the market. Like my user pic. Then you know you have one of the more popular techtipians around you.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/119003-fan-aesthetics/#findComment-1592591
