hello all,
For a school project i am creating a 3D object viewer using OpenGL, what features would you consider to be key for such a project? Any responses would be appreciated.
-matty
If you judge a fish based on its ability to climb trees it will go its whole life thinking its a failure.
https://linustechtips.com/topic/1189972-3d-rendering-project/
- Being able to rotate the model would be nice
- A  panel with some info on the 3D model (filename, location, amount of vetexes/polygons, size, etc.)
- buttons to quickly look at the object from the top/bottom/left/right would be nice to have
- Turn on/off a light
- Render modes which show the edges of the vertexes/polygons
- 'Proxy mode' (basically a way to render a simplification/low 'res' version of the file to render quickly).
Those are some of the things I would want to have in a 3D model viewer. Probably ranged from 'easily added/necessary features' to 'cool to have/great to show off your prowess as a programmer'.
https://linustechtips.com/topic/1189972-3d-rendering-project/#findComment-13568188
That's a large project for school work. Just getting the polygons display properly is a huge task. If a triangle is half behind another one you need to only draw it partially and the Z order won't help you.
That being said the easier to implement and can be tweaked alot is the post processing part. Anything, anti-alias, super scale, smoothing, bloom, color temps, sharpen, blur.
https://linustechtips.com/topic/1189972-3d-rendering-project/#findComment-13573920
1 hour ago, Franck said:
You can have a triangle with a larger Z buffer than another triangle that pass over a lower Z buffer one.
I don't quite understand what do you mean. The depth buffer has the same dimensions as the rendered image, there is a depth value for each pixel, but you don't even have to deal with it just enable GL_DEPTH_TEST and OpenGL will take care of it.
When 2 triangle is on top of each other (or really close) that's can cause stitching, but it's more like a modelling issue.
ಠ_ಠ
https://linustechtips.com/topic/1189972-3d-rendering-project/#findComment-13577354
21 hours ago, DevBlox said:
If it'll build on Linux, I'd sure have a try.
probably not cos id be using a few external libraries for it which im not sure if they will
https://linustechtips.com/topic/1189972-3d-rendering-project/#findComment-13600128
