Asus Monitor VG278HE 144HZ with MSI RTX 2060
Hi All,
Previously I had a Zotac 1060 mini card which was giving me 144hz refresh rate on Asus VG278HE monitor through DVI Cable(while 1060 had inbuilt DVI output port).
but now I have upgraded to MSI RTX2060 card which doesn't have DVI port on it so I am connecting through Dual link converter(Display port to DVI) but it does not showing any option of more than 60hz rather than 144hz in setting.
So Help me
How can I get 144hz refresh rate with these ?
Card:- MSI RTX2060
Monitor:- Asus VG278HE
Cable:- DVI Duallink
Converter :- DP(Display Port) to DVI (Dual link ++D)
Am i missing something ?
Is it not possible?
I have to buy something else?
You should just use a HDMI. But in the future get a moniter with a display part that way you'll get the best performance.
Is it limitation of monitor or my Graphic card ?
does this configuration(Combination) not support the 144hz refresh rate
It limitation of the actual cable it doesn't matter it both can get 144 fps/hz if the connection is bad then it ruins everything. So the connect proable doesn't support it. HDMI is ur best option
which Monitor You suggest for Gaming purpose which is compitable with gcard 2060.
Sceptre E255B-1658A This one is always going out of sale because ppl are oppressed with it cuz its $170 for a 165hz
Asus VG278QR This is my personal monitor it amazing 0.5 ms
MSI Optix MAG241C Really good one as well
Thank you Very Much sir but can you guide me how HDMI is my best option will it give me less command delay in game compare to DVI input
48 minutes ago, JenuGamesYT said:
Hi All,
So Help me
Card:- MSI RTX2060
Is it not possible?
It might be the DisplayPort to DVI adapter in some cases.
You need to carefully read the product description for those adapters -- some can only do 60Hz...for some reason.
HDMI 2.0 and DisplayPort is capable of delivering 144+ Hz, and higher resolutions.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Linus can tell you for me, But display is best for for computers  the goes hdmi then dvi then vga the monitor does not have a display port connector so go hdmi
