First time coding. It basically calculates the nth term for a simple quadratic sequence. Are there any ways I can make it better
number1 = float(input("Number 1"))
number2 = float(input("Number 2"))
number3 = float(input("Number 3"))
number4 = float(input("Number 4"))
number5 = float(input("Number 5"))
sequence = [number1, number2, number3, number4, number5]
print(sequence)
#Calculating difference 1
dif1num1 = number2 - number1
dif1num2 = number3 - number2
dif1num3 = number4 - number3
dif1num4 = number5 - number4
#Calculating difference 2
dif2num1 = dif1num2 - dif1num1
dif2num2 = dif1num3 - dif1num2
dif2num3 = dif1num4 - dif1num3
dif_array = [dif2num1, dif2num2, dif2num3]
print(dif_array)
#Confirming quadratic
valid1 = int(0)
valid2 = int(0)
valid3 = int(0)
if dif2num1 and dif2num2 == dif2num3:
    valid3 = valid3 + 1
if valid3 == 0:
  print("The sequence is not quadratic")
var_ns = dif2num1 / 2
one_n_squared_1 = 1
one_n_squared_2 = 4
one_n_squared_3 = 9
one_n_squared_4 = 16
one_n_squared_5 = 25
new_n_squared_1 = one_n_squared_1 * var_ns
new_n_squared_2 = one_n_squared_2 * var_ns
new_n_squared_3 = one_n_squared_3 * var_ns
new_n_squared_4 = one_n_squared_4 * var_ns
new_n_squared_5 = one_n_squared_5 * var_ns
diff1 = number1 - new_n_squared_1
diff2 = number2 - new_n_squared_2
dif_01 = dif2num1 / 2
dif_02 = str(dif_01)
dif_03 = (dif_02 + "n squared")
diff_final = diff2 - diff1
diff_final_str = str(diff_final)
print(dif_03 + "+" + diff_final_str + "n")
Please tag me @Windows9 so I can see your reply
https://linustechtips.com/topic/1189021-quadratic-calculator-first-code/
You could accept inputs in a loop and place them in a list rather than assign a distinct variable to each of them. This would also allow you to expand your program to a sequence of arbitrary length. In the same way you could generate the powers of each integer programmatically, in a list.
Also all the "new" variables are redundant, you could have just run the multiplication while declaring the "old" ones.
sudo chmod -R 000 /*
(caveat emptor, I speak C-like languages better than Python)
I suspect in this line you mean...
if dif2num1 == dif2num3 and dif2num2 == dif2num3
... otherwise you might just be checking if dif2num1 is not 0 (at least in C it works that way; Python might just be that smart).
On a higher level: using a loop to run through your first array to validate the first and create the second array (so your input data could be arbitrary length), and another loop to validate the second and create the third (etc.), and then another loop to validate the third.
Loops are your friend, especially in work like this. It also makes fixing algorithmic mistakes much quicker because you don't need to change n-lines of code every time, just one.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
I'm suspecting this is python? If so, you don't need float on the numbers or int on the valids, python will take care of that for you and convert where necessary.
You don't appear to be using valid1 or valid2, so those aren't necessary.
This is casting dif2num1 and dif2num2 to booleans, and with floats that means that what this is actually saying is
if (dif2num1 != 0.0) and (dif2num2 != 0.0) == (dif2num3 != 0.0):
What I suspect you want is for all three to be equal, which would instead be represented as
if dif2num1 == dif2num2 == dif2num3:
Mixing variables with the same naming style but totally different data types can get confusing fast. Python also does a lot of easy conversion with strings, so you could write this whole block as
dif_03 = (dif2num1 / 2 + "n squared")
And as others have mentioned
Cats Wanting Fruit Loops | Know Your Meme
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
