Opinions on Case
Go to solution Solved by Eschew,
Hey there. The Cooler Master Q300L is a pretty good budget M-ATX case, it has magnetic front and top panel dust filters for easy removal and cleaning, and it has decent thermals thanks to its mesh/perforated front panel (although, consider adding more case fans, if possible). Do note that the MSI B450 TOMAHAWK is an ATX motherboard, and will not be physically compatible with the M-ATX case. The MSI B450 GAMING PLUS does come in an M-ATX form factor, though, so if you go that route, you're good.
Note: Not quite sure what the "Gaming Pro Plus" is, do you have a link to that motherboard?
With everything I can afford out of stock I have more time to save up. So I'm thinking of getting a case and this is Amazon's best seller. Is it as good as it seems for the price?
https://www.amazon.com/Cooler-Master-Transparent-Adjustable-Ventilated/dp/B0785GRMPG?ref_=s9_apbd_otopr_hd_bw_b2Ore&pf_rd_r=HQTPC7SRWA6ZDWEF3SSR&pf_rd_p=e40229b8-d5c6-5de6-b0fa-db4711b23251&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=572238
Plan on sticking an MSI B450 Tomahawk or Gaming Pro Plus. One has better sound, the other Type C plug
https://linustechtips.com/topic/1187600-opinions-on-case/
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
https://linustechtips.com/topic/1187600-opinions-on-case/#findComment-13551956
