Hello, it's my first time posting here.
I've recently built my first desktop PC, and I'm having a little trouble.
My system has 3 drives; a 250GB m.2 SSD, a 1TB HDD, and a 3TB HDD.
I planned on using my SSD as my boot drive, and the 3TB HDD as my data drive.
I've configured all of my "My Documents"-ish folders to be on my 3TB HDD, and have been installing all my non-essential programs to the same drive.
For the past few days, I've been getting notifications saying that my boot drive is full, so I went to check my boot drive.
It says my boot drive is 232GB / 232GB used, and there are 191GB worth of applications on this drive.
But from what I can see, there are only 5GB worth of programs installed on this SSD...
Even if I uninstall a program (like photoshop), and re-install it to my HDD, the unused space refills as I re-install the program on a different drive.
Have I configured my storage incorrectly, or is there some other kind of problem?
I haven't been able to find a post where there seems to be a similar problem.
If someone could help me fix this issue, or point me to a post, it would be great.
thanks for your help in advance.
kwazuki
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/
It's in the windows settings (sorry it's in Japanese...)
the first category translates to "Applications and functions" I think.
If I click on the "Applications and functions" it looks like this
It's sorted by size, and all the rest are microsoft things.
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/#findComment-13548751
There's a free program called TreeSize. It can show you exactly how big each folder on your drive is, which will hopefully enable you to identify the problematic program.
Ryzen 1600x @4GHz
Asus GTX 1070 8GB @1900MHz
16 GB HyperX DDR4 @3000MHz
Asus Prime X370 Pro
Samsung 860 EVO 500GB
Noctua NH-U14S
Seasonic M12II 620W
+ four different mechanical drives.
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/#findComment-13548756
@kwazuki
Just a thought, do you by chance have Windows backup enabled? At one point I had Windows set to backup one of my drives, but had the drive that contained the backup included in the list of drives to backup. Might be a bug that's since been fixed, but it didn't take long for my 1 TB drive to fill up since it essentially became exponential file size growth. Oops.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/#findComment-13548765
WizTree is a really nice utility to keep on hand.  You can set it so it runs from a USB thumb drive which is nice if you have multiple PCs. Some times Windows apps save stuff to the C; drive if they have not been configured.  I had this issue several years ago with a common streaming app whose default cache location was on the C drive and it filled things up pretty fast.
Workstation PC Specs: CPU - i7 8700K; MoBo - ASUS TUF Z390; RAM - 32GB Crucial; GPU - Gigabyte RTX 1660 Super; PSU - SeaSonic Focus GX 650; Storage - 500GB Samsung EVO, 3x2TB WD HDD;  Case - Fractal Designs R6; OS - Win10
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/#findComment-13549211
thanks everybody!
I've identified the problem using WizTree! (It would've been possible with WinDirStat as well though)
there were gigantic log files (like a 85GB txt file...) in some of the programs I've been using.
I've moved the log files to the HDD, and my SSD has free space now!
thanks again for everyone who helped!
kwazuki
https://linustechtips.com/topic/1187188-c-drive-fullbut-how/#findComment-13549818
