Hi last christmas I upgraded my pc to a Ryzen 7 3800X, MSI Gaming Edge WIFI Motherboard, and the Corsair H60 AIO water cooler. Just recently I started monitoring my pc's heat, and when idle on the desktop im at temperatures of 68-70 degress celsius, and I dont think thats normal, and during gaming like call of duty modern warfare I get from 71-80 degrees celsius. I dont know if my airflow is the problem or I need to upgrade my AIO cooler but I'm getting nervous.
Pc Specs:
Ryzen 7 3800X
MSI Gaming Edge WIFI Motherbaord
RX580 8gb Graphics Card
Corsair rgb 16gb 2666 ram
TT Riing Plus fans
600w EVGA Bronze Power Supply
Corsair H60 AIO Water cooler (its a sing fan but i installed 2 on each side)
WD Black M.2 SSD
Seagate 2tb HDD
NZXT H500 Case
I uploaded pictures too.
https://linustechtips.com/topic/1185759-pc-overheating/
Welcome to the forum!
The 3800x is a much higher TPD chip than something like the R7 3700x or R5 3600 so more heat out put is to be expected. I upgrade my R7 1700 to a 3800x as well and saw a good increase in temps. But the H60 is not a great cooler to start off and the H510 is a nit lacking in airflow, but more importantly you need to check your voltages. By default your motherboard may have your voltages cranked (this was the case with mine) and with some tweaking you can lower temps by a lot.
I recommend looking in oyur bios and seeing that everything is set to, if need be adjust accordingly.
Voltages:
-          CPU Core Voltage – Manual Mode – 1.2500V (offset mode if you want to get into more fine tuning)
-          CPU SOC Voltage – Manual Mode – VDDSOC 1.1000V
-          1.8V PLL Voltage – 1.8000V
-          1.05V SB Voltage – 1.0500V
3rd gen Ryzen performs best under cool temps, so lowering the voltage to 1.2500V is safe and best for long term use. I have improved system stability and overall performance while lowering temps with my R7 3800x following this method. And my CPU can now sustain max boost speed for longer because of the lower temps.
Good read on voltage issues with the new Ryzen CPU’s: (And why I recommend low voltage)
https://www.reddit.com/r/overclocking/comments/ejd5c9/1325v_is_not_safe_for_zen_2/
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1185759-pc-overheating/#findComment-13538169
57 minutes ago, RoboMan14 said:
Ok thanks Ill check that, what cooler do you recommend me upgrading too?
Do you want to stick with a AIO, or try an air/tower cooler instead?
If you go with an AIO, you want to get a 240mm or 280mm radiator cooler.
The H500 can support both 240mm and 280mm at the front.
  • EVGA CLC 240 or CLC 280
  • Corsair H100i or H115i
  • NZXT X53 / X63
If you go with an air cooler, IF you don't already, add 2x 120mm/140mm fans to the front to get more cool air coming into the system.
The front of the H500 is pretty restricted, so getting higher quality / static pressure fans is recommended.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1185759-pc-overheating/#findComment-13538701
A good mid range air cooler will do just fine.
https://pcpartpicker.com/product/PnPKHx/arctic-freezer-34-esports-duo-cpu-cooler-acfre00061a
https://pcpartpicker.com/product/wPkj4D/deepcool-neptwin-white-7434-cfm-cpu-cooler-neptwin-white
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1185759-pc-overheating/#findComment-13539039
