You'll pay more with NZXT, but supposedly BLD is really good in terms of system integrators so your money would be well spent. I havent done the cost breakdown as to exactly how much theyre charging, but if you can justify to yourself the difference in cost between building it yourself and paying BLD to do it then go ahead.
But, building a PC is really fun and worth learning.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13522783
I’m also leaning more towards nzxt bld just because there would be less warranty to worry about but I’m wondering how hard of often do parts fail so that I know how much that will differ in which to choose.  I want the on to last as long as possible without failing any help is appreciated
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13522902
One question before I dive deep into this: what is your budget?
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13522963
I've gone ahead and did a simple comparison assuming a $1200 budget.  Also to answer your question, about less than 5% of PC parts overall fail out of the box, though it depends on the build quality.
Here's a build I used to compare to NZXT's BLD service.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.15 @ Walmart)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($91.99 @ Best Buy)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($82.99 @ Amazon)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($118.99 @ Newegg)
Video Card: EVGA GeForce RTX 2060 6 GB KO GAMING Video Card  ($299.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case  ($69.99 @ Best Buy)
Power Supply: EVGA BR 600 W 80+ Bronze Certified ATX Power Supply  ($79.48 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($106.99 @ Other World Computing)
Total: $1024.57
Generated by PCPartPicker 2020-04-25 00:38 EDT-0400
NZXT BLD: $1,228.91 pre-tax
PCpartpicker build: $1024.57 pre-tax with Win10 ($917.58 if you just use the free installation from the Microsoft website)
About a $100 shipping fee and a $100 build fee, which isn't bad
Let's use CyberPowerPC and iBuyPower as a couple more places to compare from.
CyberpowerPC: $1,381.00 (lowest possible as the motherboard selection is X570s only, $1,321 w/o Win10)
iBuyPower: $1,333 ($1,273 without Win10, X570 motherboards only)
They charge more than NZXT for almost the same build, except with a X570, but the cheapest X570 is only $50 more than the B450 Tomahawk and not the extra $100 they charge you over NZXT. Given those facts, they have an extra $50 fee compared to NZXT's BLD service.
NZXT BLD service is one of the cheapest ones without going for a pre-built that has a cheap crappy motherboard and a crap PSU (I know since I have a pre-built as my main rig, added some more RAM and storage myself.)
You save a lot more money with building it yourself, but you might run into headaches if there is a faulty piece of hardware and you don't have the means to troubleshoot. So basically, do you value the $200 as a safety precaution, go NZXT BLD and let them build it, or do you build it yourself to save money?
MAIN PC:
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13523108
I’m leaning more towards nzxt bld just because there would be less warranty to worry about but I’m wondering how hard of often do parts fail so that I know how much that will differ in which to choose.  I want the pc to last as long as possible without failing any help is appreciated
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13524416
That's a really vague question, but if you buy cheap parts they will fail more often. For example a cheaper SSD will not last as long as an expensive model. If you cheap out on the PSU you could potentially kill your whole system even, that's why people generally recommend to buy a quality PSU.
I don't know what exactly you're asking but here are some RMA rates for GPUs since the 5000 series was discussed a lot in the media: https://www.reddit.com/r/Amd/comments/f6q2pl/rmarates_hardware_defects_rx_5000_series/?ref=share&ref_source=embed&utm_content=title&utm_medium=post_embed&utm_name=2e4bdc7a953544859bf72cc9a85b7826&utm_source=embedly&utm_term=f6q2pl
So I guess there is a 2-3% chance that something is wrong with your GPU if you buy a 5700XT at mindfactory and you ignore all other data.
I would build it myself just for the cost savings alone.
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13524482
if you treat the pc right and don't put cheap parts in it then it will last you a long time. If you clean inside it and make sure it is not getting suffocated with dust build up if you do that it will last you a long time. But for peace of mind and warranty the nzxt bld is a good choice to go with but if you do a custom build most components do come with pretty long warranties.
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13524485
What are you planning to use the computer for and what is your budget for the system, if you build the system yourself, you would still have the warranties from the different brands of products which you buy for the system? If you are using good parts and build the system yourself, it should last as long as or even longer than a pre-built computer would.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13524491
* threads merged and moved to the New Builds & Planning section *
Please, do not create multiple threads about the same subject.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1183567-nzxt-custom-build/#findComment-13525182
