I want to get a 2070 super but stick close to 500 usd price, I saw the evga gaming xc model for 519 but now out of stock, my case is h200i red and black with rgb mobo and ram , with red extension cables, does anyone think the founders edition green colors with a red build look could blend well
https://linustechtips.com/topic/1182356-need-anesthetic-help/
I expected a much different thread, based on the title!
Anyways, a FE card will likely fit in just fine (IMO) in you aesthetic, as long as the GEFORCE GTX logo does not light up (I am not sure if it  does anymore?).
Plus you also have the 'super' on the shroud that is green. Not sure how that will fit in. You could make fill up that space with some elctrical tape (like 'fill in' each letter with tape or something).
Or just don't care about it. In my experience, you will look at your PC for the first couple months and then not care anymore.
https://linustechtips.com/topic/1182356-need-anesthetic-help/#findComment-13514227
