you likely won't need any more. there maybe a point to grabbing a cheap 1tb SSD just to move stuff onto.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1181502-need-more-storage/#findComment-13508005
3 minutes ago, MKSanic said:
so ive been wondering whether i truly need a hdd for storage since i already have a 1tb nvme m.2 ssd. i do light blender and modded minecraft. i will also use it for school work
Depends. Is your 1TB SSD nearly full? You need more storage. If not? No(t yet).
Plus of course you need room to backup too.
https://linustechtips.com/topic/1181502-need-more-storage/#findComment-13508011
An SSD needs to have 20-25% free space (unused empty space) on it for best performance and drive life. As long as you use no more than 75-80% of the formatted volume of the drive, you don't need anymore room. If you do need more room, a 2.5" SATA SSD or HDD will work fine.
You do need to backup any drive you do have. Backups must be on external backup drives that are kept disconnected from the computer, powered down, and stored away from the computer except while updating the backup or restoring from it. A backup kept on a drive in the computer is worthless since anything that destroys data in the computer can also destroy the backup.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/1181502-need-more-storage/#findComment-13508516
