Have you tried controlling fans first?
Also please post your current fan model, your case and your motherboard. The odds are that you have the best fans for the budget you are going for.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1180425-fans/#findComment-13499630
Fan model names? There are several Air series fans. Which headers are you powering each fan off of? What rpm are they running at? Have you tried lowering fan speeds?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1180425-fans/#findComment-13500737
20 hours ago, turismotom100000 said:
Corsair air series and a tomahawk b450
https://www.corsair.com/eu/en/Categories/Products/Fans/c/Cor_Products_Cooling_Fans?q=%3Afeatured%3AfanModel%3AAF%2BSeries&text=&pageSize=#rotatingText
Whats the budget total or per fan? AF fans are really cheap already.
Your motherboard has already enough fan headers, so there's no need to buy hub.
https://linustechtips.com/topic/1180425-fans/#findComment-13503527
