Proprietary dell motherboard cpu cooling solution
Solved by samuraishogun1,
I will check it out. I will likely get a better system anyways, but I guess that an expensive motherboard or zip ties are your options if, for some reason, you can't upgrade.
Featured Topics
1
tippytipper ·
Posted in Storage Devices1 -
2
AlyShazli ·
Posted in New Builds and Planning17 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
3
3
Rusty Proto ·
Posted in Programs, Apps and Websites0
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
