Instead of that SSD I would get something larger like the Crucial P1, but overall that looks pretty good.
 CPU: I9-7900X RAM: 64GB (16X4) DDR4-2933 GPU: RTX 3080 MOBO: ASUS X299 Deluxe PSU: Corsair RM850 SSD: ADATA XPG SX8200 PRO 1TB HDD: Seagate Barracuda 2TB Case: Corsair iCUE 465X Cooler: Corsair 280 AIO
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487752
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487761
get a 1600AF and B450M Pro-VDH instead, much better than the 9100F.
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487762
i am concidering a regular ssd tbh, dont think shell ever need that kind of speed, and i could get more storage that way
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487765
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487774
2 minutes ago, Meganter said:
hows that better? 9100f outperforms 1600 in games by like 10-15% and is newer...
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487775
Just now, TheOrangeBoy said:
I stand corrected. cpu.userbenchmark must be on acid.
Also I added a 1660S instead of the 1660 which is also better, and since it comes with a CPU cooler you don't need that either.
Also userbenchmark is very bad and is very biased towards Intel, I'm saying that and I own a i7-8700K.
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487800
3 minutes ago, Meganter said:
It's overall better :
The i3 9100f is just a rip off 4c/4t compared to the 1600AF 6c/12t.
will it be worth to cough up 25$ more for 2600?
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487801
no. the 1600af is liteerally a 2600 with a worse memory controller. so the only difference is thatt you might be able to run ram at 3200 on the 2600, but only at 2933 on the 1600af. not really worth the price difference.
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487807
The af for all intents and purposes is a 2600 with a different name. It's also on zen+ as the 2600 and the 1600af is basically there to continue on using the 1600 name.
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487808
3 minutes ago, TheOrangeBoy said:
i dont think ill be overclocking. its a small case, and a small cooler and i want the system to stay quiet.
It's basically a 2600. I have a 1600AF with a RX 5700 (non xt) and it easily plays 1080 and 1440 games at 60+ fps...I'm also using 3200mhz RAM
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487825
The memory controller isn't worse.  It's a 2600 up and down.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1178846-micro-itx-build-for-gf/#findComment-13487841
