Trying to split the costs a little bit, I have an 8700k and an MSI z370 -A pro. While I have been happy with the performance so far, I am starting to look into upgrades, most likely to  9th gen intel. Would I be better off just getting the 9th gen coffee lake and popping it in to the z370? or getting a z390 board now and waiting for the 9th gens to go down in price a bit.
or should i make the switch to ryzen instead?
I mostly play games, do folding@home, and then random browsing and projects on this pc.
If your question is answered, mark it so.  | It's probably just coil whine, and it is probably just fine |   LTT Movie Club!
Read the docs. If they don't exist, write them. | Professional Thread Derailer
Desktop: i7-8700K, RTX 2080, 16G 3200Mhz, EndeavourOS(host), win10 (VFIO), Fedora(VFIO)
Server: ryzen 9 5900x, GTX 970, 64G 3200Mhz, Unraid.
https://linustechtips.com/topic/1178533-upgrade-mobo-or-cpu-first/
Are you not getting the performance you want out of the 8700k?
Sounds like you have a good CPU for your goals. Six solid cores will serve you well for those tasks for quite some time yet.
Quote
Then you'll definitely be wasting money by upgrading either. Performance will only get cheaper between now and the time you really have something noticeable to gain from upgrading.
ok, so maybe I am just getting a little bit of FOMO or something, i don;t know what the term is for it but like wanting to upgrade just because. However i will say that the motherboard I have really bothers me. It has as stupid white led on it that i can't figure out how to turn off. not like an led light, but a led strip integrated into the pcb.
1 minute ago, StewySphinx65 said:
Do you absolutely need the upgrade from a 8700K? I have a 7700K and it's more than capable of running AAA games and Folding@Home. What graphics card do you have also?
2080
Well, in that case you can upgrade whatever you just feel like, as it would all fulfill that desire while being equally irrelevant for the day to day experience.
21 minutes ago, StewySphinx65 said:
Then I would say that a 9th gen is probably more suited for a 2080, i have a feeling there's probably less chance of a bottleneck
If he has an unreleased 500Hz monitor, maybe :P
An 9th gen CPU may be no upgrade at all depending on how lucky he gets in the silicon lottery. Ultimately, the "9th gen" is just the "8th gen" with more cores at the top of the lineup, which itself was the 7th gen with more cores, which was the 6th gen with somewhat higher clocks ¯\_(ツ)_/¯
Accessories, displays, high speed storage are all better upgrades
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
with a 8700k, i recommend just waiitng for zen 3
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I think that is a great idea and something I hadn't considered.
That is also probably smarter eh? I have been on intel for a long time, so maybe just holding out a little longer for zen 3 is the way to go.
I have an I7 4770 and I also would like to upgrade, but it's still doing everything I ask it to do quite well so it would be throwing money away in an upgrade if I don't even see that much of a performance gain.  If I spend close to 1.5k on a ryzen upgrade and I ask myself if the improvement in performance was worth that much money, I want the answer to be yes ... and it will be yes when I'm not able to play the game I want at the fps I want.  That's why it's not worth it for now and I'm waiting for next year to upgrade.  In the meantime I would really like to have a I7 K cpu to overclock but even that is not worth it unless I can find it for under 50$ cad. ... anyway just my 2cents
If you really want to upgrade stuff maybe look for peripherals or some nice audio solution ... then become an audiophile keyboard addic ... ;)
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
