Getting back into the swing of things, so I drug my PC out of the closet after a few years and it hasent stood up to time very well. Currently has an fx-8320 black edition on a GIGABYTE GA-970A-DS3P,with 8gb of hyperx Blu ram, a  pny gtx 650ti, and a Corsair cx 600 psu. As I am a AMD fan boy id prefer to go the ryzen route and want to try to stay under 1,000. Mostly will be used for gaming and media. No desire to stream lol. Any suggestions are greatly appreciated.
https://linustechtips.com/topic/1178116-help-with-new-build/
11 minutes ago, CtrlAltDie said:
Getting back into the swing of things, so I drug my PC out of the closet and it hasent stood up to time very well. Currently has an fx-8320 black edition on a GIGABYTE GA-970A-DS3P,with 8gb of hyperx Blu ram, a  pny gtx 650ti, and a Corsair cx 600 psu. As I am a AMD fan boy id prefer to go the ryzen route and want to try to stay under 1,000. Any suggestions are greatly appreciated.
suggestion 1: sell your machine on craigslist for like...120$ to get money toward something, or exactly this:
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor  ($117.35 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3400 Memory  ($83.99 @ Newegg)
Storage: ADATA SU635 960 GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($496.98 @ Newegg)
Case: Phanteks Eclipse P360X ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: EVGA SuperNOVA GA 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($116.98 @ Newegg)
Total: $1100.27
Generated by PCPartPicker 2020-04-15 00:19 EDT-0400
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482298
Memory: Team T-FORCE DARK Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($64.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ B&H)
Power Supply: EVGA SuperNOVA GA 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.98 @ Newegg)
Total: $1081.27
Generated by PCPartPicker 2020-04-15 00:15 EDT-0400
Thank you. How big of a leap is the performance of the 2070 super over the 2060 ko?
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482306
i'd say around 12 to 18% depending on the game...when GPU limited.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482310
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.99 @ Amazon)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: XFX Radeon RX 5700 XT 8 GB THICC III Ultra Video Card  ($409.99 @ Amazon)
Case: Phanteks P300 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA SuperNOVA GA 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($75.98 @ Newegg)
Total: $1000.91
Generated by PCPartPicker 2020-04-15 00:23 EDT-0400
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482320
Just now, kyn1972 said:
I would swap the 1600 out for the 2600 which newegg has a sale on for 124.99 currently but otherwise a very good build suggestion up above.
the 1600 AF is the same as the 2600...just cheaper...same 14nm chip.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482321
Total: $1000.91
have to cut down too much to fit the 3600 in, now you have worse motherboard, worse RAM which is also out of stock at this price, worse SSD (faster but half the size), worse case and worse PSU. And most important much worse video card.
For a 15% faster CPU and a 2tb hard disk drive. not worth the cut :)
Worst case he upgrade to a newer ryzen cpu in a year with 8 or 10 core the tomahawk board will take it.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482325
Odd, neweggs list the 2600  as a 12nm. Guess they typoed but then again they do have thousands of items for sale so it probably happens fairly often.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482327
Odd, neweggs list the 2600  as a 12nm. Guess they typoed but then again they do have thousands of items for sale so it probably fairly often.
humm not sure then but i know for a fact the AF is faster than the original 1600 and in testing was the same as the 2600 if running the same clocks (ship 200 mhz slower base clock i think) but i would tune it to 4.0ghz and call it a day anyways.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482330
if i'm not wrong zen was on 14nm, zen+ on 12.
1600af and 2600 should be both on 12nm
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482334
13 minutes ago, i_build_nanosuits said:
I've seen Ripjaws V 3600 C16 for $75-$80. Faster memory for less :)
"hi 911? my grandma is on the floor and shes not responding to anything"
"have you tried turning it off and on again?"
ding ding ding ding ding ding ding, di-di-ding
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482335
they are both 12nm. the listing on pcpartpicker is what confused me.
the thing is, i picked the Gen 1 ryzen, defenetly swap it for the 2600 then:
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482337
and tighten memory timings. super important for ryzen, and there's a neat tutorial here. no trial&error, and is basically idiot proof
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482338
Never mind, one dollar more lol
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482339
Fixed everything: better memory, better CPU, one less hamburger in your pockets:
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($125.98 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($76.99 @ Newegg)
Total: $1101.90
Generated by PCPartPicker 2020-04-15 00:31 EDT-0400
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482341
@732 what the fuck is your sig 😂
but going with a 1600af and a 5700xt is a good way to stay all amd
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482364
Ahh, I wouldnt sweat it as considering how fast AMD is releasing their new chips its easy to get confused though if someone was to sweat over AMD it might be Intel.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482366
Google Search: What are the mario bros views on....
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482368
Worst case he upgrade to a newer ryzen cpu in a year with 8 or 10 core the tomahawk board will take it but not the gaming plus.
I don't really see much of a difference between the Gaming Plus and the Tomahawk except for Type-C and some heatsink. Also the case and psu are good enough.
Updated List R5 3600
Memory: G.Skill Flare X 16 GB (2 x 8 GB) DDR4-3200 Memory  ($68.99 @ Newegg)
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card  ($499.99 @ Best Buy)
Total: $1094.92
Generated by PCPartPicker 2020-04-15 00:50 EDT-0400
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482382
Both got the same VRMs.
Total: $1101.90
That PSU is way too expensive, you can get similar quality for less or better quality for the same price, and 650W isn't really necessary in this build.
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482405
Also, r.e. the PSU, there don't seem to be any reviews RN and the policy is generally to assume it's a bomb until proven otherwise. So you're gonna want something like a Seasonic Focus+ Gold or similar
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1178116-help-with-new-build/#findComment-13482426
