Need Help regarding GPU upgrade
Solved by DailyProcrastinator,
Welcome to the forum!
20 minutes ago, Hao_pengyou said:rx 480 nitro saphire 4gb <---------------------------------- This is what i'm hoping to upgrade
My budget is roughly up to £650. (currently in UK).
I'd say the RX 5700 XT is by far the best value and makes the most sense, but if you really are stuck on G-sync I would get a 2080S, they start very near your budget.
