Help undervolt R5 3600 using Ryzen Master
1 hour ago, BulletproofPancake said:How do I undervolt my Ryzen 5 3600 using Ryzen Master because eco-mode has way too much of a performance impact and I've read that undervolting does a better job keeping performance.
First thing first, what motherboard are you using?
There are a few settings in the BIOS you'll want to mess with in order to get your 3000 CPU working smoothly.
But, to answer your question blindly, on Ryzen Master, select a profile you want to edit. (Profile 1, Profile 2, Creator Mode, Game Mode are the options) Then where it says "Peak Core(s) Voltage" Just turn that down a tiny bit, hit "Apply + Test" on the bottom to make sure it's a bit stable, then run a Cinebench R15 run to make sure its more stable. Then repeat, knock the voltage down a bit, test it, and keep doing that until it fails to complete the test. After that, turn the voltage back to your last stable setting.
