I’m building my first computer ever. I bought an Asrock B450M Pro 4 and 2x8 ddr4 at 3200 speed. I know my board supports dual channel but I’m not sure which slots to put the sticks into. They are labels A1, A2, B1, B2. Do they go in A1 and B1 or would they be put in A2 and B2. Does it matter? I’ve read all over the manual and can’t seem to find anything mentioning it. Just a chart that might be it, but honestly I don’t understand it. Thanks.
ive included some pictures from the manual if it helps. I’m running a Ryzen 5 2600
https://linustechtips.com/topic/1174894-dual-channel-help/
You'll want to use slots 2 and 4 (count from the left side/CPU socket side).
https://linustechtips.com/topic/1174894-dual-channel-help/#findComment-13457328
3 minutes ago, jaslion said:
Normally it's A1 B1. But a lot of boards don't care about which pair you do anymore nowadays.
As far as I know and remember, older boards suggested A1 B1 but the newer ones suggest A2 B2. Either way, the best way to know is to consult the manual, let's just agree on that. :P
https://linustechtips.com/topic/1174894-dual-channel-help/#findComment-13457340
