Hey guys i got like 45-60 fps on rust and if i lower the setings is not doing anything(i got low fps on most of the games)
Pc specs:
RTX 2070 armor 8g
I7-2600k 3.4ghz
32Gb ram (ddr3) speed:1600
My drivers are up to date,my Gpu usage/temp is 45%-60%/32C*-40C*   Cpu usage/tepm  50%-70%/70C*/95C*
Edited by Andrei Zhuang
https://linustechtips.com/topic/1174287-low-fps/
You're getting 95C on your 2070?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1174287-low-fps/#findComment-13452599
11 minutes ago, Niklos said:
Mine (2070 S) get as hot as that and, according to Zotac, it is normal.
No it is not. That's going to damage the card in not that long. Nvidia have stated that at 95C the card should turn off so as to avoid critical damagw
Pc specs:
RTX 2070 armor 8g
I7-2600k 3.4ghz
My drivers are up to date,my Gpu usage/temp is 45%-60%/85C*-95C*   Cpu usage/tepm  50%-70%/60C*/70C*
Your CPU is overheating
https://linustechtips.com/topic/1174287-low-fps/#findComment-13452647
I did not remember exactly what they told me so I did some research and here it is (copy/paste) : "4. Operating temperature varies from 40c to 50c in idle. Load temperature can be from 60-90c depending on load. The thermal threshold of the card is 95c and considered overheating if it is running at that temperature in a long period of time."
https://linustechtips.com/topic/1174287-low-fps/#findComment-13452673
In terms of temperature, 95°C on the GPU at less then full load is not acceptable, what pc case are you using and what fans do you have and where? As for bottlenecking that gpu, yes, your 2600K would bottleneck pretty much every card faster than a GTX 970 or GTX 1060.
https://linustechtips.com/topic/1174287-low-fps/#findComment-13452751
His card is at 50% usage and 90C. That ain't normal mate
https://linustechtips.com/topic/1174287-low-fps/#findComment-13452909
