Posted April 4, 2020 For some reason when I launch D2 it's stuck at 128mbp I don't know why. I believe my memory settings in my display is wrong, this is my info: ALSO, This is the same for the 2 displays connected to my Graphics Card AND the 2 displays to my Motherboard (yes I have 4). Total Available Graphics Memory: 16315 MP Dedicated Video Memory: 8192 MB System Video Memory 0 MB Shared System Memory: 8123 MB (I have two 8GB sticks of RAM) Last of all I can't download the latest "Intel® Graphics - Windows® 10 DCH Drivers". Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 4, 2020 Sounds like the game may default on the integrated graphics. Figure out how to select the display adapter (or change it from some ini / cfg files in the game/ user folder for the game) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 4, 2020 Author 20 minutes ago, mariushm said: Sounds like the game may default on the integrated graphics. Figure out how to select the display adapter (or change it from some ini / cfg files in the game/ user folder for the game) I don't know how. Do you have any links? Also it also started opening on a different display than it usually does. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 4, 2020 Author Solution Solved Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
