Top fan as intake or exhaust
Tech Reprise
Suppose I have two fans on the top. Will putting one fan (the one nearer to the front, on top of the ram and cpu cooler) help in cooling the pc anymore efficiently? Or should I just lower its speed so that it doesn't exhaust the cold air that's coming from the front intakes. Or will it just make a negligible difference?
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Depends on the system. If cooling is already good, adding another fan probably won't make a notable difference.
Just as with rack mounted servers, all my builds are designed to cool from front-to-back.
You don't want positive pressure with all fans blowing in, and you don't want to create negative pressure with all blowing out. You want to move ambient outside air into, through the case, and back out.
I've got a case with 2x 140mm fan in the front. Fans at the top are optional, but consider one at the rear if heat build-up under load is still an issue.
I can tell you that in my define R6, I added 2 top fans and played around with them as intake and exhaust. This system is folding@home right now, and per my measurements its kicking out ~600w worth of heat. I have 2 140MM's in the front, and one in the back. Those are stock case fans, the top fans are silent wings 3.
Relevant specs are as follows: Ryzen 9 3900x, Stock cooler, RTX 2070, GTX 670
Top fans as intake: CPU temps never reached above ~75c, even while folding. Top GPU, the RTX 2070, was overheating even with the fans at full boar. Bottom GPU was uncomfortably hot, but more acceptable
Top fans as exhuast: With both GPU's loaded, and CPU at idle, the heat kicked off my GPU's is managing to make the CPU idle at ~55-65c. This is almost certainly the result of the down-firing stock cooler, but i felt it worth mentioning. CPU temps while folding are solid at 83c. GPU temps are MUCH lower. I'm having issues finding work units on my RTX 2070 right now, but it normally settles in around 80c, the GTX 670 (which has been folding all night) is sitting at 75c. Both cards are Gigabyte Windforce 3x. This is my recommended config.
But, in the end the only answer is the one you find for yourself with experimentation. You don't have a Define R6 as far as I can tell, so the above results may or may not be of use to you. Pick up a couple cheap fans, throw them in, load up prime 95, furmark, and HWInfo, and see what works best.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Physics : hot air rises, so you'll get better results 'going with the flow'. Try to redirect the intake from the front fans with some tubing to the hottest heat sources, rather than inverting the upward hot air flow.
Warm air rising is negligible when there's any active airflow.
