Best Ultrawide Monitor For The RTX 2080ti
Solved by Curufinwe_wins,
2 minutes ago, Ahmed Kirito said:Understood, but LG's monitor has 144Hz & freesync, while Dell's monitor has 120Hz & Gsync, So I guess that dell would be the best choice, what do you think?
https://pcpartpicker.com/product/DcsmP6/lg-34gk950g-b-340-3440x1440-120-hz-monitor-34gk950g-b
https://pcpartpicker.com/product/fBvbt6/acer-predator-x34-340-3840x1440-120hz-monitor-x34-pbmiphzx
https://pcpartpicker.com/product/c9qbt6/dell-aw3418dw-341-3440x1440-120hz-monitor-aw3418dw
The LG variant you are looking at yes is the freesync version, the gsync version is identical (34GK950G-B).
So honestly, just look at those three links, buy the cheapest one in whatever country you live in.
