I have a question. 2 days ago i got a new build. MSI B450 MAX GAMING PLUSS, RTX 2060 SUPER, RYZEN 5 3600 and a Corsair CV550. I did not upgrade my ram because i have 16gb ddr4 2400 MHZ. Is it worth upgrading from 2400 too 3200 or 3600????
https://linustechtips.com/topic/1169855-ram-speed/
There would be a slight performance increase, at least in some games.
However, it's not really worth the money at all unless the few more FPS will really float your boat
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
https://linustechtips.com/topic/1169855-ram-speed/#findComment-13415385
Whether its worth it or not depends on your needs. If you are getting enough performance that you are satisfied with, it is not worth it.
Honestly, you can just run the FCLK up to 1800MHz and keep the RAM at its current clocks and you will get more performance out of your CPU without having to upgrade RAM.
https://linustechtips.com/topic/1169855-ram-speed/#findComment-13415429
