What internet speed is enough?
EL02
I wanna know what internet speed is enough for watching 720p videos on three devices at the same time. Thanks!
30 or 60 fps?
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
About constant 20mbps should be fine. Considering that you always get a bit less than the advertised speeds I would get at least a 30 mbps plan from an ISP.
Unraid Server
i would say, about 10 mbps is enough for one device with no buffering, so 3 devices at least 30 mpbs but look at higher speeds prices, if its really low between 30 and lets say 50, get 50 in case in the future there would be more devices.
50 is okay for that.
PC:
CPU: AMD Ryzen 5 2600
GPU: MSI GTX 1070 8GB
Storage: WD Blue 1TB HDD, WD Blue 500GB SSD
CPU Cooler: NZXT Kraken m22 AIO Cooler
RAM: 16GB 2666MHz HyperX Fury
Motherboard: GIGABYTE B450M DS3H
Case: Phanteks P400
PSU: EVGA 450BV
i have like about 20-30mbps speed and tested it with 2160k idk what fps on my pc 1080p50fps and 720p 60fps on my phone is good enough with no buffering.
okay. im getting a 30mbps plan then. thanks
  • 3 weeks later...
Update: I got a 15mbps plan because 30 wasnt available in my area and it is enough for iptv streaming at 1080p/720p and watching 480p yt videos across 3 other devices(youtube's highest video quality bc of covid19) while still having 4-5mbps left, thats what ookla speed test is showing. Just pointing out if this answer comes up in a google search.
480p is not "youtube's highest" it's jsut the default that you can switch back to anything else.
F@H
GPD Win 2
oh what!! thanks for letting me know. i just read somewhere that it couldnt be toggled back to 1080p and didnt even try at all.... im dumb
