do i need a microphone upgrade?
TheNuclearBrony
currently have a CAD U37 with pop filter. it doesnt sound that great to me. do i just need to play around with audacity more or is the mic not good enough and i need a better one?
What are you planning on doing with the mic? If you're gonna upgrade, go with xlr and an actual audio interface, usb sucks. If you need help choosing, this website from a youtuber called podcastage recommends the best interfaces and mics for every budget
im recording youtube videos with it
I just looked it up and it sounds horrible and keeps clipping, for the same price you could get a behringer umc22 and xm8500 (+cable of course) which is amazing for starters. So yeah, you need an upgrade
interesting. at the time of purchase (2 years ago) the reviews said it was great for the value. plus i figured anything was better then my built in webcam mic
that sounds disgusting
for comparison here's what I recommended (pops a bit but you said you have a filter so thats a non-issue)
interesting enough the pop filter he has in his hands is the same exact one i have lol
interesting enough it's the same one I have too lol
thank you for the suggestions. now i just need the money lol
it's 15 bucks plus xlr to 3.5mm cable if you dont want an interface (he doesnt use one in the video, it's still good)
i did plan on getting that interface u had suggested as well. what other cables would i need?
xlr female to xlr male, that's it. The interface comes with an usb cable used to connect to your pc.
i found an amazon basics cable lol. good enough?
cables dont really matter for sound. dont spend a fortune on it, amazon basic should be adequate
awesome. thank u so much. i appreciate the help
One thing i'd like to add though, if you buy a really long cable, like 3+m (10ft i think) it might pick up noise, so get something shorter
shortest one is 6ft. i dont think ill need anything longer as its for youtube lol
If you're recording for youtube and want that stereotypical sensitive/detailed sound I'd move more in the direction of an XLR condenser mic than the XM8500.
The two most popular bang-for-buck condenser mics have to be the AT 2020 and the MXL V67G, the 2020 has a USB version if you really don't want to go down the audio interface route but I would advise against USB mics just for the upgrade path options an interface provides.
Personally I have a UMC1820 interface and while I have a modest collection of mics I use a Behringer C2 pencil mic for talking on discord/recording basic voice stuff or streaming. It's a really cheap option that sounds pretty great (for the price) and it's low profile. When recording singing/instruments I'll pull out something a little higher end but there are always cheap options that are more than good enough.
Hope that helped,
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
5 hours ago, TheNuclearBrony said:
well i dunno wat direction to go to now
If you're having trouble deciding I absolutely agree with Fox, if you can't try them out for yourself go to YouTube and check out some reviews/tests of each mic whether on the podcastage channel or somewhere else. In the end what matters is how it sounds on your voice and frankly none of us can predict that beyond real broad statements.
Sloth
@rice guru
Sloth
i do think dynamic is a good option. it cancels out most of the background noise and is direction to only my face.
