Need help with my speakers
Jimmy69
So I finally got my setup ready and my dad got these old Technics sc-eh600 that work perfectly. I wanted to connect them to my PC but they don’t work for some reason. I connected the aux cord to my PC and no sound is coming out. The speakers have a “Input selection” button that lets you select input I guess. It has AUX mode and it is on but still doesn’t work. Any ideas? I can send pictures or take a video if needed.
Check the speakers with something else if it doesn't work it's the fault inside the speakers, if they work try re installing your sound drivers.
And you  seem new here, this topic is supposed to be in the audio subforum.
This subforum is only for tech related discussions. It'll be moved by a moderator soon be careful while posting
-= Topic moved to Audio =-
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
