razer kraken pro?
nickedition
I had my krakens for 1 year and they broken. and I want to buy new krakens but are there other recommended headsets?
Budget, location?
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
Budget, location?
around 80 euro's and I'am from the Netherlands
Location, budget and what type of headset you want (open or closed design) ?
I do not really have a preference for open or closed
I've heard decent things about the Siberia V2's from Steelseries.
Can't you go with Headphones + a mic?! would get better sound quality.. Obviously up to you though :)
Maybe something like: These Pioneer SE-A1000 Over-Ear Stereo Headphones for $54 and a mic like this Zalman Zm-Mic1 For $7 would be awesome in your budget... Due note that these headphones are open though so sound will leak.
PROFILEYEAH
What do people even put in these things?
If you need a mic, get the sennheiser 449 and a clip-on mic at about 80 € but if you don`t need a mic, just spend that 80+ euro and buy the HD 518. This is what I would do, btw I hate headsets.
HD439 over the 449, as they sound the same, and the HD439 has velour pads and a detectable cable.
I think I will go for headphones and save some money for a mic.but I have a question is there any difference between sennheiser hd 449 and 439 beside looks?
haha my page refreshed to late but thanks for answering
Not a problem, I do really like, friend and I swap headphones from time to time, and I was content (though the quality was far less) with the HD439 when he borrowed my SRH1540's.
Please don't buy Razer, they are overpriced and terrible. How about try the Steelseries Siberia V2 instead.
what about this one, I dont know about sounds but the construction looks strong. http://m.philips.nl/m/hoofdtelefoon/voor-over-het-oor-zwart-shp8000_10/prd/nl/
Would be okay? Not the best, but not really bad.
How about no headsets at all?
yes I know mine broke in 1 year, that's why I want to buy new ones.
  • 2 weeks later...
I want to thank everyone why helped me to find new headphones, I bought the Philips shp8000 and they sound far better than the razer kraken.
My razer krakens a few days ago, never getting a razer product in the future..
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
