Hello,
Is it normal that my overclocked Ryzen 1600 runs at 33C above ambient constantly and sometimes peaks 46C above ambient under load ?
Perhaps the thermal paste isn't spread well enough?
CPU cooler : Noctua D15s with one extra A12x25 in the front
CPU power consumption is around 85~90W under load.
Case : Lian-Li O11XL with 3 A12x25 side intake, 3 A12x25 top exhaust, 1 A12x25 rear exhaust
Ambient temperature : 29C
Intel I7-10700KF stock - Noctua NH-D15 - A15+A12x25
Micron Ballistix Sport LT 4133MHz CL17-21-21-40 @1.45v
GIGABYTE AORUS 3090 Xtreme 1905MHz@0.919v/2010MHz@1.063v +900/750 memory clock
Seasonic PX-1000
Lian-Li Lancool II Mesh
https://linustechtips.com/topic/1169290-noctua-d15s-temperature/
32 minutes ago, ThiccSmough said:
Hello,
turn on the a/c!
33 minutes ago, ThiccSmough said:
Hello,
for comparison I have a cheap Cooler Master 212 LED on a ryzen 2600 that stays around 38c for normal tasks and around 62c on load.  If I stress the CPU, I can get it to about 72c.  It is about 20c in the room
4 hours ago, LogicalDrm said:
By constantly you mean even when CPU load is under 15%? Cause the temps are rather normal for load.
I mean that when CPU is under load (100% usage), the CPU temperature is 33C above ambient.
Idle temperature is around 4~5C above ambient.
Seasonic PX-1000
Then its normal. Its also bit hard for me to count those as its rare to see temps given as delta instead of total.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
