Looking to finally retire the ol' WD Blue HDD, currently have eyes set on 860 QVO or a BX500 since their 1TB/960GB versions fit my $150 budget. I just wanted to ask what will I be sacrificing in each case compared to an EVO/MX500? For the purposes of game & general media storage (not the kind of critical data I would even bother backing up, so longevity really isn't a concern) which is the better option? Or, given the $150 budget and the ~1TB space requirement, is there any better-value alternatives?
EDIT: I should clarify that this is a CAD$150 budget, not USD.
https://linustechtips.com/topic/1164567-qlc-or-dram-less-pros-cons/
I'm assuming this is not US dollars, or at least not US market, right?
Since I see the SSD's you're talking about - the 860 QVO and BX500 - are cheaper than 150 USD - 110 and 100 USD respectively.
Either way a Crucial MX500 or 860 EVO makes more sense in my mind. Or a budget NVME like a 660p (if your board supports M.2 NVME/PCIE).
QLC drives have a shorter life-span in terms of writes to it and a DRAM-less SSD will become slower once filled up more.
The qvo has fast read speeds but worse write speeds, and the evo has less disparity between the two, leading to a faster overall ssd. I personally have a samsung 860 evo and its really fast, definitely would reccomend going with the evo. The bx500 has similar read speeds to the qvo but has a write speed thats 23mbp/s faster than the qvo, and the evo has slightly faster read speeds with the write speeds being 40mbp/s faster than the bx500
Straight up looking at the (by the manufacturer) reported read/write speeds is definitely not the way to go in comparing SSD's of three different technology types (TLC + DRAM, TLC and QLC).
There is a much larger difference between the drives when it gets to filling up the drive further or when working with large transfers (when not having the cache will be noticeable).
Between the 2 I'd definitely go for QLC rather than DRAMless.
The scenarios where QLC slowdowns will be significant are not that common, maybe when installing a game or writing a large file once in a while, however a DRAMless is a PITA constantly with every random access being slowed down if there are multiple concurrent accesses - and there always are.
Here a TLC 1TB SX8200Pro is $160. Definitely go for that instead if it's an option where you are.
F@H
GPD Win 2
