Need more ethernet Ports
Jimkirk363
Right here's my issue, i've run out of Ethernet ports on my Router, all 4 are being used.
Would it be possible just to add a switch to the network to add more ports?
Would i run into any configuration issues running things like Printers, and a NAS.
When getting a switch are there any features i should be looking at to get?
Thanks
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI  with BIOS 4703, AMD Ryzen R9 3900XT + Corsair H115i Pro RGB XT Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  1 x Samsung U28E590D & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Barracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, ICYBOX IB3740-C31 & ICYBOX IB3640-03,  MZHOU 7 Ports PCIe USB 3.0 Card, 1 x XIAOLO 2.5G Intel I225V Ethernet Card, 2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Corsair Obsidian 750D Wind Force Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, Synology ds215j NAS + 1x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
All you need is an unmanaged switch, which if you look on amazon, go to best buy ect you can find them easy and cheap. It won't really change anything or cause any configuration issues. Most is IP address may change for your Printer and NAS, but it will still be in the 192.168.1.x ranges.
Features just depends on what you may want. A standard unmanaged one is fairly barebones. Your main differences will be ports. The amount and speeds. You can find some with SFP ports. Beyond that the switch will automatically manage the routing itself.
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RX5700XT MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD HDD: PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
Just make sure whatever switch you buy says 10/100/1000mbps and that it says Switch not Hub. Otherwise it'll do exactly what you need.
There are so many to Choose from, all different makes and model numbers.  Anyone have any recommendations?
I will pay £20 max which should get me an 8 port one from what i see.
Internet Speed.....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
No as we have concluded i need a switch.
Internet Speed.....
That's what he linked to... Budget tp-link switch. Exactly what you need, in your price bracket.
Any gigabit unmanaged switch will do.  I usually use the metal Trendnet ones.  Plug and play.
18 hours ago, Constantin said:
this is what you need?
I think that link is confusing because the first part of the URI indicates 'Ethernet Splitter', which is a thing but those (ethernet splitters) are horrendous.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
well i've decided to up my budget a little and this is what i'm ordering tomorrow....
https://www.amazon.co.uk/dp/B07QHD134G/ref=psdc_430573031_t3_B07RQHL6BY?th=1
Internet Speed.....
Good choice, it being smart managed means should you decide to do some more advanced tinkering later on you have some options.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Right i've had this switch through but i cannot seem to access its admin page.
I have downloaded the software and run it and it finds the switch, i click admin page and it just takes me to a blank page.
I have tried both Firefox and Chrome.
Anyone have any ideas?
Internet Speed.....
See my response here. You probably have a different subnet than what the smart switch uses. You'll only be able to access the switch's admin interface by changing the subnet on the client device directly connected via ethernet to the switch.
Ive sorted it.  I rebooted the switch and it immediately changed IP addresses.  I was then able to log into the admin page fine.
Thanks for help anyway :-).
Internet Speed.....
