I copy video files from one drive to another [D: to F: 1-3 GB in size] and the process seems on the slow side. After the initial spurt, the transfer rate settles down to about 60MB/s.  I'm thinking it should be faster. I'm using an Asus® PRIME Z270-P Intel® Z270 based chipset, ATX Motherboard.  (SATA III)
Assuming it should be faster where do I go from here?
Could my SATA cables be crap?
Could these two particular drives be sharing a controller slowing everything, and how would I know?
I've included the benchmarks for both drives, to see if it is the drives that are the bottleneck.
https://linustechtips.com/topic/1162767-slow-copy-speed-yes-no/
+- ST2000DM006-2DM164 (/hdd/0)
|  +- Temperature    :       36       35       36 (/hdd/0/temperature/0)
+- WDC WD4002FYYZ-01B7CB1 (/hdd/1)
|  +- Temperature    :       42       42       42 (/hdd/1/temperature/0)
+- WDC WDS100T2B0A-00SM50 (/hdd/2)
|  +- Host Writes    :    13959    13959    13959 (/hdd/2/data/0)
|  +- Host Reads     :     9773     9773     9773 (/hdd/2/data/1)
One is the SSD boot drive...btw.
https://linustechtips.com/topic/1162767-slow-copy-speed-yes-no/#findComment-13355347
seems fine, esp for hdds that are half full.
https://linustechtips.com/topic/1162767-slow-copy-speed-yes-no/#findComment-13355355
If these were SSDs I'd say there's definitely something afoot. Mechanical drives on the other hand can only go about as fast as what you're benching. Totally normal.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1162767-slow-copy-speed-yes-no/#findComment-13355744
