I am given to understand The 3900x cools ok at stock with the stock cooler which is a whisper less powerful than the dark rock slim which is a 120mm 3 pipe tower cooler.  Iirc it’s 145mm tall.  A 4 pipe cooler would do a slightly better job than that.  There are also a few low profile coolers that would work well.  They’re low not thin though and tend to require more longer pipes to do the same job.  “Slim” is a strange and somewhat vague requirement.  I am curious as to the particulars.
https://linustechtips.com/topic/1162092-slim-105w-cpu-cooler/#findComment-13349631
First, start by checking what case OP is using.  Hmm, ghost S1?1078119066_Screenshot_20200305-131602_SamsungInternet.thumb.jpg.fd7ee0a642ee06a6cf32696799e45b6d.jpg
Ahh, perfect!  Slim = low profile, based on this wonderful piece of contextual knowledge.  Now that we have enough information to actually help OP, let's start formulating a response.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/1162092-slim-105w-cpu-cooler/#findComment-13349679
@Agent of Fortune The ghost would pair nicely with the noctua L12, I'm not certain if the L12s is compatible but there's a pretty solid chance it is.  Otherwise you can look into the AXP-100, AXP-92, L9a with shroud or a larger fan, maybe a jonsbo cooler.
https://linustechtips.com/topic/1162092-slim-105w-cpu-cooler/#findComment-13349687
This will work, not sure if Noctuas brown and beige colors are okay, I couldn’t find this one in black.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1162092-slim-105w-cpu-cooler/#findComment-13349706
