Does European power supply with american cord work?
Solved by seon123,
7 minutes ago, uApple said:my friend recently took a look at the inside of the power supply
Yeah..... I wouldn't trust that friend with anything PC related.
7 minutes ago, uApple said:The power supply input current is rated at 230Vac, and i assume that lower input current of 110 in Canada will be no problem?
It is a problem. Power is a function of the voltage and the current. So half the voltage means twice the current, and the components on the PSU aren't rated for that.
On lower end and budget PSUs you'll sometimes find that they support 230V only, as it helps reduce cost.
