Hi guys.
I have have a dell optiplex (I5-3570, 8gb DDR3)with an upgraded power supply and an rx 580 but im getting stutters in games and I have no clue what it is. The temps are fine for my CPU and i believe my GPU in gta it stutters sometimes.
cpu in games i 99% and gpu is 80% so not much of a bottle neck. I have tried ssd's,max performance in task manager, updated power usage to maximuim performance, set priority on high on games and the list goes on so I really dont know what it could be.
Any help will be much appreciated.
Thanks!
https://linustechtips.com/topic/1160235-please-help-i-have-stutters/
The CPU is maxed out, so yeah it's a bottleneck
Primary PC:
PSU tier list
How many watts do I need?
What other games are you playing?
What is your ram configuration? Are you running dual or single channel?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Im playing games like paladins rn but that doesn't stutter but gta v and fortnite stutter quite heavily which annoys me but the have a pattern. Both stutter because the roads/buildings aren't loaded in. This happens in loads of games its just i play more easier to run games so usually it doesn't stutter with them. my ram is quad btw
What graphical settings are you using? You may need to adjust them to put more load on the GPU.
System specs below
PSU: Corsair CX650M
Ive tried highest and lowest nothing helps
Did you try any in between and what is your FPS.
System specs below
PSU: Corsair CX650M
11 minutes ago, MrEpicBruh said:
Any solutions?
Thanks
a better CPU. the main problem is that your current hardware is too weak for the games you're playing
Gta 60fps
Fortnite 140+ fps
both of these games are hard on the CPU
the only thing I could think is to reduce the population settings in GTA since those are CPU intensive
Primary PC:
PSU tier list
Thanks, But gta v reccomend the i5 3470 and i have the 3570 so mines better than the reccommended or is it just inacurate game developers guessing?
17 minutes ago, MrEpicBruh said:
Any solutions?
Buy a new cpu.
As the minimum. The game does run, correct? You're getting the minimum experience.
sudo chmod -R 000 /*
1 minute ago, MrEpicBruh said:
Any affordable ones?
i7 3770/s
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
The i7 2600 is pretty cheap on eBay
Primary PC:
PSU tier list
GTA should still run fine, What are your temps and ram usage? Also check if other programs are running in the background.
System specs below
PSU: Corsair CX650M
A sandy/ivy i7 would be ok but only if the price is good (<$60), and I'm not sure I'd trust a random optiplex with a cpu it didn't come with.
