Setting up LAG with Unraid
Solved by Electronics Wizardy,
5 hours ago, wolfslab said:There can be lots of users hitting the server at once, so I wanted increased bandwidth to make sure there wouldn't be any bottlenecking. There is gonna be at most a small amount of 10Gb clients. Most are gonna be 1Gb clients.
Are you using smb? Smb3 is still normally a better route.
Also unraid is known for being slow, so if you want speed id pick a different os and storage system.
