Okay so the Cougar MX 330G has no grommets and the disgusting cables in the back can be seen, is it possible to make my own DIY cable managemenr bar?
it's either that or i try and make my own grommets.
CPU: i5 4670k @4.1ghz | GPU: Gigabyte Geforce GTX 1060 G1 Gaming 6GB | MB: Gigabyte Z97P-D3H | RAM: 4x4GB Generic | SSD: Gigabyte 240GB
PSU: Antec High Current Gamer 650 watt | Case: Cougar MX330G
https://linustechtips.com/topic/1159051-diy-cable-management-bar/
You can buy grommets. Both Bill at @Mnpctech and modmymods have rubber grommets based on the size you might need.
https://www.mnpctech.com/products/pc-cable-grommet-large
https://modmymods.com/computer-cases/grommets.html
for me i'ts hard to come by so that's why i'm going the DIY route @TVwazhere
I see. In that case, I'll move this thread to Case modding and Other Mods to best reflect the type of answer you need :)
I'll be sure to do that, thanks.
but it is in Case Modding and other mods XD
That's because I already moved it ;)
maybe I should make a separate thread for this, but I've had such a hard time finding soft rubber grommets (with membranes) in any variety of sizes - the circular grommets here look pretty good, but only come in one size. for building custom cases or cabinets I'd definitely want to be able to source larger grommets as well. do you know of any other good suppliers?
@KENBAL420 I'm interested in seeing what solution you end up going with, I've been doing some mods to my living room media furniture and I'm looking for more cable management ideas.
Not of various sizes. I just knew these two were good sources for most rectangular cutouts that cheaper cases lack. Sorry :(
I found this video online and i'll maybe give it a shot. I can't get rubber grommets in my area so a DIY solution would be the best route for me to go.
got these too, https://www.mnpctech.com/products/round-pc-cable-grommet
all cable grommets only .99 each!
corsair_cable_grommets_psu_holes_800d_90
17 years of helping you void your warranty
