Recently, a small buissiness approched me to build a server. Problem is that they were on a strict budget but still wanted some pretty heavy power. Me, being dumb and young, decided that it would be a good idea to try and run desktop parts instead of real server parts since they are cheaper. Here are the specs:
( I run a RAID card in RAID1 with the 2 SSDs)
I soon found out that windows server 2016 doesn't like windows 10 drivers. Therefore I get constant blue screens and overall a lot of problems. It is my first time building a server so I don't have any experience in that domain. This is why I come to you LTT hivemind. I need a solution but I can't really afford to pay more than 200$CA ish.. I can probably get a refund on most of the pieces since they are almost all bought from Amazon.
Thank you for your time !
https://linustechtips.com/topic/1158960-i-need-help/
Would they accept 2nd hand parts? You can get some pretty good deals on LGA2011-v3 parts right now. Xeons, RDIMM memory, etc.
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13322802
you could get windows 10 pro to work. 2016 server should, any idea what driver isn't working right?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13322807
It does blue-screens with different error codes everytime while updating and straight up doesn't let me install any windows 10 drivers for the chipset or the ethernet card.
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13322821
You can save considerably on memory (it doesn't need 32GB, 16 GB will do just as fine) and PSU, as the system won't need a 1kW PSU, IMO a 750W version would suffice and you might get away with a 600W PSU as the GPU doesn't need much power.
Oh wait, you already purchased it ?
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13323117
Can you unzip the drivers and force install using the .inf file?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13323430
I also wouldn't recommend running the memory at high speeds. Run them at loose timings and don't aim for 3000 as TR 1 is not exactly easy with memory compatibility.
Might be that your memory settings are highly unstable.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13323435
I found a way to bypass the windows version check with the ethernet driver (here is the link: https://blog.workinghardinit.work/2017/06/19/installing-intel-i211-i217v-i218v-i219v-drivers-windows-server-2016-eufi-boot/ ) but never found a way for the chispet.
https://linustechtips.com/topic/1158960-i-need-help/#findComment-13324709
