Hey guys. I’ve been watching videos about how to choose a good motherboard and I’ve noticed a lot of times Linus, Jayztwocents, Paul’s Hardware and other Tech YouTubers mention “VRM cooling”. Jay even called VRM cooling a “feature not a gimmick”, and I’m wondering..
What is VRM cooling and what does it do in regards to performance?
Also does my motherboard have good VRM cooling? ?
Thanks!
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
The VRMs are the power delivery to your CPU. The VRM area is directly above and to the left of the CPU socket, and you can sometimes judge VRM cooling by the size of the heat sinks (although sometimes the heatsinks are large but with little surface area for heat dissitipation)
The MEG Z390 ace has good VRM thermals.
https://www.guru3d.com/articles-pages/msi-meg-z390-ace-review,20.html
Primary PC:
But why do VRMs need heat sinks?
But like..how does that affect performance? I mean if you have two motherboards and one had terrible vrm cooling and the other has amazing vrm cooling would there be any sort of tangible performance benefit? Or would it just be the peace of mind or knowing the vrms are cooler?
It deals with lifespan, and possible overheating depending on how much work you make them do. Properly cooled MOSFETs(that's what VRMs are composed of) will last longer and are less likely to overheat. They may also run more efficiently.
Ohhh ok thanks!
So it’s not better for overclocking or anything like that? It’s just a durability issue?
Anything that produces heat that puts it above its safe operating temperature needs a heat sink
Better VRMs and better cooling means better power delivery, this better overclocks and better overall performance.
More heat = more resistance, so power delivery is worse. Also, excessive heat will degrade the VRMs. Motherboards with weak VRMs will be programmed to deliver less power, so you'll end up with lower CPU clocks.
Primary PC:
SEVERE CPU throttling or outright restarts.
Perfect example is AMD FX processors on OLD Phenom2 Motherboards that were patched to support FX, but didn't really handle it at all..
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
if i had to bet on which component in a pc would fail first, it would be the mobo vrm, they have a finite hour of life base on actual temps and is usually the hottest component in a pc (unless it's a gigabyte master with its gorgeous heatsink, 60C inside a case lol), on a z390 taichi/ace it's not unusual to see 80C load temps during the summer, and those are considered good boards.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
They don't always. If the power requirements are low enough for what the manufacturer is intending, you can get away with not having any, and just utilize the heat dissipation of the device itself. When you start cranking up the power requirements, MOSFETs get real hot, and will overheat, which will probably cause them to fail prematurely and run less efficiently.
Ohhh ok thanks!
For the most part. Like mentioned above, you can have system restarts, but let's say you don't have those, and you're riding on the point of overheating, but not quite there...then it's a durability issue. Those VRMs being pushed without heatsinks being on them will see less life due to the harsh conditions.
I've seen MANY FX processors (3.5-4Ghz near constant) on crap motherboards be put to 1.4Ghz for extended periods (10-20 seconds every 30 seconds) because the VRMs got past their temp limits.
Games stutter, performance is craptastic.
Power delivery is quite important and often over looked. They need air flow. Something im trying figure out at the moment, but the heat sink is decent for my lower end chip not sucking to much power. Using an AIO is good for cpu and nothing else.
Ryzen 7 5800X3D , Corsair H105 , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , EVGA RTX 3070Ti FTW3 ,  WD SN850 / MP44L
ASUS MG279Q , Corsair Carbide 275R , G403 Hero
