Hello guys, I am here once again to ask for your suggestions.
My brother is looking to upgrade his pc and buy himself a new case, and his budget for the case is about 60 euros. He wants the case to have the space to hide cables and the power supply, I don't know the actual name. What could I get for this budget?
https://linustechtips.com/topic/1158058-best-case-for/
This should fit the aesthetics, it's a pretty awesome case for that price.
https://geizhals.eu/be-quiet-pure-base-500-grey-bg036-a2126916.html?hloc=at&hloc=de&hloc=eu&hloc=pl&hloc=uk
CPU: AMD Ryzen 9 3900X | Motherboard: ASUS ROG Crosshair VIII Formula | GPU: AMD Radeon RX 6900XT | RAM: 2*16GB 3200MHz 14-14-14-34 G.Skill Trident Z Royal Silver | SSD: 2TB Gigabyte Aorus Gen 4; 500GB Samsung 860 EVO | CPU Cooler: Corsair H115i RGB Platinum | PSU: Corsair AX850 | Case: Corsair Crystal 680X | Monitor: Eve Spectrum 4K | Keyboard: Logitech G513 Romer-G Tactile | Mouse: Logitech G502 Lightspeed
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13315932
I should've pointed out that we're italians. On amazon this case goes pretty much over our budget. However you reminded me I need to check out be quiet's offerings
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13315935
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13315951
Typically this is referred to as a PSU shroud or a PSU basement.
https://it.pcpartpicker.com/product/ptKcCJ/phanteks-p300-tempered-glass-blackred-atx-mid-tower-case-ph-ec300ptg_br
https://it.pcpartpicker.com/product/6qPKHx/cooler-master-masterbox-mb500-atx-mid-tower-case-mcb-b500d-kgnn-s00
*internally* dont make an Italian joke, dont make an Italian joke, dont make an Itali-
*Slaps roof of PC case* These bad bois can hold so much spaghetti!
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13321395
3 minutes ago, TVwazhere said:
*Slaps roof of PC case* These bad bois can hod so much spaghetti!
>hod
Well done.
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13321403
2 minutes ago, DildorTheDecent said:
>hod
Well done.
Dont bully me I am a sick mod ???
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13321412
Deep Cool Matrexx 55 Mesh
https://it.pcpartpicker.com/mr/amazonit/b9tKHx
It may not look flashy, but works quite well for air coolers. If you go with a AIO cooler, a 280 or 240 would be best. A 360 AIO can fit, but it's not as easy to install the radiator and fans between the front case bracket.
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13323719
can it contain pizzas too?
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13333624
Margherita, Sicilian, Calzones, Romana, hell you can do pepperoni or Hawaiian; whatever floats your Mediterranean boat. These bad boi's can hold it all.
Except Deep Dish. That's a literal pie not a pizza.
https://linustechtips.com/topic/1158058-best-case-for/#findComment-13340199
